Gears or Torque Converter
Old May 11, 2004 | 05:20 PM
jmrinaudo's Avatar
Which would be a better buy next. Right now I got SLP intak, exhaust, headers. Now looking to make my next purchase would like to no which would be better to buy 3.73 gears or TC with a 2800 stall.
Old May 11, 2004 | 05:38 PM
madwolf's Avatar
If you have 2.73 gears right now, do gears first. Otherwise, do the stall.
Old May 11, 2004 | 06:34 PM
baron4406's Avatar
Listen to this man. If you get a stall with 2.73's when you drive on the street it will blow big time. Get the gears first then get a stall, it helps that "dead spot" you get with a high stall converter on the street.
Old May 11, 2004 | 07:26 PM
ping0317's Avatar
if you get the gears first make sure you have really good tires! Without traction, your power is no good.
Old May 20, 2004 | 07:52 AM
ping0317's Avatar
Ok, I am getting the Richmond 3.73 Gears...no more 2.73! I have a couple of questions
1. Richmond is a good brand right?
2. Do I still need to put the GM Additive ?
3. Does the 3.73 gear only help on the take off or all around power?
4. Do I need to buy the install kit? I was assuming that all I need is the oil and gasket
Old May 20, 2004 | 10:52 AM
19formula94's Avatar
Never heard of this..what will blow big time, the performance?
Old May 20, 2004 | 07:51 PM
redzsmoked212's Avatar
1.richmond whine but they are stronger cause of the way they make them.
2.not sure what kind of additive you need to use but you dont have to use the gm additive i didnt.
3.it will definetly help a lot on take off but still give you all around better performancs (make sure you get good tires).
4.you need the kit cause its always a good idea to replace the bearings.
Old May 20, 2004 | 08:20 PM
Somnambulist's Avatar
I had a Vig 2800 when my car used to be an A4 with 2.73's...nothing "blew" concerning drivability or performance-wise...
Old May 21, 2004 | 12:06 AM
yeah we have a guy here running low 12s with a 35 stall and 2.73s...performance and good drivability.
Old May 21, 2004 | 07:36 AM
ping0317's Avatar
Smile
I just ordered a 3.73 richmond gear. I will let you know after the install. I can not wait!
Old May 21, 2004 | 08:26 AM
ping0317's Avatar
quick question, I currently have a TCI 2600-2800. If I install 3.73 gears, I wil have no traction at all right? So I am thinking of going to 3.42? What do you think
Old May 21, 2004 | 08:30 AM
ping0317's Avatar
I still want good traction when I am driving on the street just...
Old May 21, 2004 | 03:13 PM
3.73 just get dr by nitto
Old May 21, 2004 | 04:01 PM
a stall will cut your 1/4 by ~.5 seconds...gears will cut it by ~.2 on a near stock car, and that's being optomistic...
QuickSilver02
Apr 7, 2015 11:12 AM
armedtrigger
Feb 24, 2015 08:30 PM
StansZ28
Feb 19, 2015 07:39 AM
PCLZ28
Parts Wanted
Feb 12, 2015 11:35 PM
Collector Car
Dec 17, 2014 01:12 PM
