Clutch toast?
Old May 9, 2004 | 04:59 PM
Bando's Avatar
Clutch toast?
For about 2 days now, I've noticed something funny with the clutch but I just figured it was something to do with the temperature outside or something. Anyways, for some reason I noticed a bit of a "clunk" feeling in the gearshift when coasting slowly to a stop and putting it in first gear. Today, when I was in first gear at a stop, I can feel something travelling up the gearshift, like it's not completely in disengaged, and the car wants to creep forward.
By the time I got home, I can hardly put it in gear at all and the clutch fluid was really low I added fluid but it didn't help.
As a side note, I recently (2 months ago) had to replace my mcleod adjsutable master cylinder with my old stock one, because a seal had gone or something and the fluid kept contaminating, but the fluid in the new one looks OK and I don't think that's the problem.
Please let me knowwhat you think this might be! I just want to go to the tranny shop armed with some knowledge
ps- I can sort of hear a "clunk" when the cutch plate slaps against the flywheel (i think that's what it is!) and it's more pronounced lately.
Old May 10, 2004 | 09:22 AM
Bando's Avatar
By the way, for about 8 months the clutch, off and on, has made a "swhirring" noise sometimes when I release the pedal and the clutch is engaging. I think something may have happened to one of the springs last year when I was stuck in a traffic jam during the blackout. But the spring thing is just a guess, I really am a bit confused. I figured if the clutch was going out, it would slip, it's not slipping at all from what I can tell, car still slows down if I drop gears.
Old May 13, 2004 | 03:02 PM
TW95Z's Avatar
If your clutch fluid was low I suspect that you have a leak (probably in the slave). That coupled with the fact that the McLeod master has been replaced with the less efficient stock master is giving you the disengagement problems.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
