new slp ctuch slipping, replace or fix?
My new slp clutch is slipping. It has about 4000 miles on it. I bought the slp clutch and pressure plate, then had the flywheel turned. A shop did all the work. I know the slp clutch isnt much better then stock, but i dont have a lot of major mods, i dont see why it is slipping already.
So is there a plroblem with the clutch or the istallation? Or was i just beating on it to much?
Can i replace the clutch plate with something better, and keep the pressure plate?
My relevent mods are:
Cold air intake, mac headers, hooker catback, high flow cat (soon to be offroad pipe), 1.6 roller rockers
with my mods now the clutch is just barely strong enough. I also have a pretty crappy set of tires on the rear, i think when i get a new set of tires, and start hooking up better, the clutch is going to give.
Also i would like to start spraying, so there is no way my current set up will hold.
So i need a setup that will work for the mods above, plus a pair of drag radials and anywhere from a 100 to 150 shot
if i swap in a mcleod disk, will i have to resurface the PP and flywheel agian? its only been about 4000-5000 miles
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Brake_L8
Jan 20, 2015 09:44 AM
