What are the symptoms of a bad throwout bearing???
Old May 10, 2004 | 02:59 PM
GONE's Avatar
Having some issues with my T56 after a long drive where the car has been on the freeway for over an hour.
When I downshift coming off a freeway ramp or something, I hear a funky grinding noise coming from the trans. Not the same as scratching a synchronizer, its a low pitch grind as I let the clutch out. If I push the clutch pedal in and out before hitting the gas, it'll do it multiple times.
After I am off the freeway and doing stop and go driving, it'll do it downshifting into every gear pretty much.
At first it was only the forward gears for some reason, i.e. downshifting to 5th and 3rd, but now it's pretty much every gear.
IT DOES NOT HAPPEN IN DAY TO DAY STOP AND GO TRAFFIC.
I feel like it would be the throwout bearing getting super hot from the driving and maybe binding or something as I down shift because the bearing is hitting a much higher rpm from the engine than it is from the drivetrain.
IT ONLY HAPPENS ON A DOWNSHIFT, NOT ANYTHING ELSE.
The clutch is a centerforce dual friction with 36k on it.
Anyone have any ideas????
Matt
Old May 16, 2004 | 10:55 PM
GONE's Avatar
nobody???
Anyone???
I know that some of you have had bad throwout bearings in one car or another before.
Help me out here.
grabbem88
20
Dec 27, 2015 07:42 PM
MyfateZ28
Jun 19, 2015 03:42 AM
SergheiS
May 16, 2015 12:12 AM
KYWes
Apr 15, 2015 07:28 PM
chuyz28
Nov 25, 2014 11:14 PM
