Driveshaft: Aluminum or Steel?
Old May 11, 2004 | 12:30 AM
BIGRED Z's Avatar
I have an 2002 Z28, A4 that came with stock 2.73's. What came from the factory, an aluminum or steel driveshaft?
I need to be sure, I thought they were all supposed to be aluminum on Ls1's, except for verts, but the dealer insists it came from the factory with a steel one. (I had it in for warranty work last week, then went to install a torque arm this weekend and came across the steel driveshaft.)
Lori
__________________
Old May 11, 2004 | 11:41 AM
teke184's Avatar
i seem to remember hearing that the 2.73 equipped cars did indeed come with a steel DS.
Old May 11, 2004 | 12:23 PM
2001NBMZ28's Avatar
My car came with 2.73's and the steel driveshaft. The 3.23 A4's and M6's have the alum.
Old May 11, 2004 | 09:26 PM
Capn Pete's Avatar
I concur .
I'm not too concerned about the steel driveshaft. IMO, it's probably stronger than the aluminum one, and I doubt that the weight difference is all that much?
Old May 11, 2004 | 10:58 PM
steve40's Avatar
if its the same driveshaft that was used on the lt1's then there is a big weight difference and you can multiply the weight by 3 since its rotating weight.
i switched to an aluminum driveshaft because my steel one had vibration problems and the ls1 driveshaft was an easy pick up
G-BODYT56
Jan 14, 2022 11:14 PM
football4life
Oct 4, 2015 07:48 AM
CARiD
Sep 30, 2015 05:44 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
