slave cylinder ?
slave cylinder ?
How do you "bleed" a slave cylinder. Do you just fill the resevoir and slowly pump the pedal? I just finished a t56 swap so I new to this stuff. Thanks for any help.
The master/slave module comes from GM pre-filled with fluid so it shouldn't need to be bled. If you think it needs bleeding, disconnect the slave from the bell housing and slowly pump the piston in and out. You can have a buddy pop the lid off the reservoir and watch for bubbles. You might want to wrap a rag around the reservoir in cause the fluid decides to splash.
jackpawt883
Sep 10, 2015 08:53 PM
