Replace flywheel durring clutch install?
Old May 20, 2004 | 10:05 AM
Valkyn71's Avatar
Going to be doing a clutch install and need to know how you can tell if you need a new flywheel?
Any easy way to tell?
Old May 20, 2004 | 11:44 AM
PatriotTA's Avatar
You don't need to replace it unless there are any cracks in it. You do need to have it resurfaced, however. Just open the phonebook and find a local automotive machine shop. Take them your flywheel and they will surface it and check it for cracks for about $40.
Old May 20, 2004 | 11:59 AM
94Z286SPEED's Avatar
always resurface when you change clutches even if no hot spots or glazing so it can mate to the new disk evenly
Old May 20, 2004 | 08:28 PM
Somnambulist's Avatar
if the flywheel seems a bit rough, you can always go across it with a fine grain sandpaper...
HectorM52
Jan 30, 2015 11:08 PM
Red_94Formula
Jan 22, 2015 12:17 AM
Jazsun
Dec 29, 2014 12:14 PM
mattszm6
Dec 14, 2014 07:09 AM
