99 T-56 reverse lock out?
Old Jun 3, 2004 | 08:43 PM
irocbob89's Avatar
Dad is putting in a 99 T-56 out of a TA into his 89 iroc with a 383 stroker. Is there a way to bypass a reverse lockout without having an electronic speedO? If there is anyway to do it please let me know, of it the electronic speedometer has nothing to do with it that would be great to. Any insite to this subject is welcome, thanks.
Bobby
Old Jun 3, 2004 | 10:15 PM
angel71rs's Avatar
It's just a solenoid so as long as you apply 12vdc on one terminal and ground on the other, it will energize. Use a switch.
Links you might find useful:
http://sethirdgen.org/t56.htm
http://www.hotrod.com/techarticles/43599/
I really like the T56 in the 98, so I'm thinking of putting one in my 71. Or a TH200r4; the TH350 suxx.
Old Jun 5, 2004 | 08:46 PM
locosteelersfan's Avatar
Wouldn't an iCAGs unit work.
Old Jun 6, 2004 | 07:43 AM
95_LT1_6SPD's Avatar
why would you want to bypass the lockout?
Old Jun 9, 2004 | 09:48 AM
MrDude_1's Avatar
just use a small black button where your LEFT hand can press it easily. and tap the 3rd brake light source for power..
Old Jun 10, 2004 | 08:30 PM
'68LT1camaro's Avatar
Lightbulb
I have a T-56 in my '68. I just muscle it into reverse. Works fine this way. As long as I don't go into reverse on the highway, I'm happy!
Old Jun 11, 2004 | 09:46 AM
MrDude_1's Avatar
uhh. wait a tic.
you have a LT1 and T56 in a 68?
your computer is setup to activate the lockout. all you have to do is wire it in. you have the parts, why not save the hassle and use them?
Old Jun 13, 2004 | 06:42 PM
Originally posted by MrDude_1
uhh. wait a tic.
I'm not using the factory PCM. I'm running a DFI gen 7 setup.
Old Jun 14, 2004 | 09:12 AM
MrDude_1's Avatar
ahhh, gotcha.
still, its just power and a ground for when you want to shift into reverse easily.
G-BODYT56
Jan 14, 2022 11:14 PM
Aaront810
Aug 29, 2020 09:34 PM
blac94Z
Nov 4, 2015 01:59 PM
colts0455
Oct 4, 2015 09:47 PM
colts0455
Sep 27, 2015 01:07 PM
