Best T56 casting number??
Is a T56 with casting number: 13-86-066-904 the one with the .50 overdrive? That's the one with the better mileage right? It's out of a '93, and I thought that years T56 had the .76 6th gear ratio?
Re: Best T56 casting number??
Rock on
I just bought a M29 to replace the factory M6 from my car which had 180k miles on it
...i think it would have lived longer if i didnt run it out of fluid
Mods and drag radials probebly didnt help it much either
Originally posted by Valkyn71
Rock on
Rock on
Are those RPO codes for the car or tranny? I didn't think the tranny had anything to do with the rear gears??
The rear axle gears only determined which 6-speed you got in '93... all 6-speed cars in 94 or later had the 3.42. In 93, you could get the standard (2.73) or performance axle (3.23) with a 6 speed. With the standard axle, you would get the M28 (junk) - it had like a ~3.36 1st gear, but the same second gear as the M29! Performance axle (GU4?) got a M29, which had a much closer 1st gear.
