rear pinion angle question
Old May 28, 2004 | 01:12 PM
1BadBrd's Avatar
i have spohn TA and i put on a moser 9" I forget how to measure and adjust the pinion angle.
Do i want the braket connected to the third member pointing slightly downwards at 2* or is the other way around?
Also i just jacked the rear end up as little as i could to fit under the car and put the angle finder on the TA braket and read the number. Do ihave to measure the DS also?
What is the easiest way to mesure and adjust for proper angle?
Old May 28, 2004 | 02:13 PM
The rear suspension needs to be fully loaded. That means either you put it on a lift that supports the wheels, or you put jackstands under the axle tubes.
Then, you want the pinion shaft and the driveshaft to form a "\ /", pointing down toward the ground. You measure the driveshaft angle off horizontal, then you measure the pinion shaft angle (using a level under the bottom plate of the TA mount), and the difference of those two angles should be 2 degrees.
Old May 28, 2004 | 06:50 PM
1BadBrd's Avatar
well, i put the rear axle on stands and the DS said -2 and the TA said 5 so the difference would be 3 correct?
If so i felt like ****, it was vibrating somethig fearce.
T
Old May 28, 2004 | 10:25 PM
If one was pointed down (-) 2deg and the other was pointed up (+) 5deg (or vica versa) the difference would be 7deg. Too much.
(-2) - (+5) = -2 -5 = -7
Old May 29, 2004 | 10:57 AM
1BadBrd's Avatar
i was afraid of that. I will change it and see what happens. Hope that little mistake was makeing my 60' crappy
oldschool
Feb 9, 2016 09:21 PM
Patricklt1
Apr 24, 2015 06:29 AM
4586
Jan 3, 2015 07:22 PM
siguy
Nov 27, 2014 10:07 AM
thenewkid
Nov 27, 2014 09:41 AM
