Pinion bearing question?
Old May 22, 2004 | 10:00 PM
Dark Angel's Avatar
OK, I just got a used set of GM 4.11's. They came with the pinion bearings. I don't know how many miles on them, so I was going to reuse my stock bearings. Also I was going to try my stock shims first. How do I remove the large main bearings near the gear? Should I soak them in gear oil and py them off? Any suggestions would be great on this. thanks.
Old May 23, 2004 | 04:45 AM
Capn Pete's Avatar
You're probably going to need a bearing puller to get that off. You should be able to get one at any place that sells automotive/industrial tools. As a rule, the pinion bearing is pressed on there pretty tight.
oldschool
Feb 9, 2016 09:21 PM
TitoPR221
Jan 29, 2015 08:00 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Jul 4, 2005 05:00 PM
kev93z28
Aug 19, 2002 12:48 AM
