Beefing up 10-bolt
Old May 17, 2004 | 02:09 PM
SOM WS9's Avatar
Question Beefing up 10-bolt
Does anyone have part numbers for Moser or Strange axles for a 7.5" 10-bolt (3-channel ABS)?? I'm also looking for a manufacturer of billet bearing caps for these rear ends.
Old May 17, 2004 | 04:45 PM
funina91ss's Avatar
If this is for a A4 car it is a waste of money to put axles in it. The only thing you can really do is buy a better posi and a solid pinion suport, TA girdle. Billet caps I think would be useless with the girdle. I went low 1.5's best being a 1.53 alot with my setup. But my posi chipped some gears off now so I am swapping out the moser in the camaro.
If it was a 6 speed then axles would still be a waste of money unless you had a spool or locker. The weak parts are the gears and posi.
Sean
Old May 18, 2004 | 01:24 PM
SOM WS9's Avatar
I want the bearing caps to keep the rear end from walking, just as an added safety measure. The axles are also a safety measure, and I want the rear to be pretty much bullet-proof for as long as possible until I feel like shelling out the cash for a 12-bolt.
Anyone have the numbers for Moser axles? Any info on the manufacturer of billet bearing caps for stock rear?
Old May 21, 2004 | 11:57 PM
SOM WS9's Avatar
TTT
Found axles, any idea about bearing caps?
Old Feb 11, 2006 | 03:08 PM
350lsi's Avatar
Re: Beefing up 10-bolt
don't buy mosers they don't stand behind there product
Lous69
Mar 19, 2015 10:20 AM
TitoPR221
Jan 29, 2015 08:00 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
CamaroBoy96Z28
May 14, 2003 09:37 PM
RedScreamin
Feb 12, 2003 12:53 PM
