Shifters????
If your talking M6, I have used the B&M and the Kirban. I loved the feel of the Kirban the best but I'm not sure they make them anymore. My second choice would be the B&M. Mine was always a little hard to get into reverse but never to bad.
Originally posted by redz2810
M T56. I was either gonna go with B&M or Hurst. With Lou's short stick.
By the way how is that short stick? does it make a difference?
Here are all the shifters I've had:
95 Formula: B&M 4 years
2000 TA: GM Hurst for
97 Firehawk: SLP Hurst, SLP Hurst w/ Lou's short stick
The stock GM/SLP Hurst are definitely better than stock, but still have a tendancy to miss 3rd under fast/hard shifting. It is a very easy shifter, though, and great for people that don't like high shifter effort.
The B&M and Hurst w/short stick on the other hand, are much heavier shift effort, but you won't have problems with missed shifts anymore. Of the two, if I prefer the B&M (never missed a shift in 4 years with it on my 95), but since the Hawk already had the Hurst I figured I'd try Lou's short stick on it. The feel and shift effort is very similar, but the Hurst w/short stick will still give occassional problems getting into 3rd (you won't hit any other gear, you'll just hit the stop between the gears if your hand position is off). Too balance this, it's a lot cheaper if you already have the Hurst, and it really doesn't happen very often. I honestly don't notice the Hurst w/ short stick being any shorter throw than the B&M was, but then I haven't done a back to back comparison either. I do definitely remember that getting used to getting into reverse was a lot harder with the B&M than the Hurst w/ short stick, but that could be because I was already expecting the extra effort.
So, if you don't already have a Hurst, definitely go with the B&M. Total cost should be about the same, and the B&M is actually better for never missing a shift. Of course, if you really want a short throw (and you have gorilla arms that can stand the super high effort), you can get Lou's short stick for the B&M as well. Just don't expect anyone else to be able to drive your car.
I like my pro 5.0
It feels very solid and the 2-3rd shift is much better. You just have to push the shifter forward, if you "aim" for 3rd like your used to with the stock shifter, you will hit the divider between 3rd and 5th
Pro 5 all the way.
I chopped mine 3/4" at first, then went with Lou's Short Stick to get that "perfect fit" feeling. Depends how close you sit to the steering wheel, and how long your arms are I guess.
CARiD
Sep 7, 2015 08:21 AM
