Tranny Pan leaking!
Old May 29, 2004 | 01:57 AM
SLeeper94Z's Avatar
Tranny Pan leaking!
well I believe my pan is warped because of it not sealing its leaked before , Do all 4l60e's have the same type of tranny pan ?
I know these trannys are used in alot of gm cars just wanna know if there all the same so I can find a replacement pan easy
Old May 29, 2004 | 02:54 AM
Johnny-Z-Man's Avatar
4l60-E Pan
I think the 4L60E pans are all the same. If your going to replace it you have several options. For Daily HP Street driving, I would replace it with an O.E.M. style 1 extra qt. pan with drain plug. It's about 3/4" deeper than stock.
Old Jun 12, 2004 | 12:09 AM
Z28Nut's Avatar
Make sure you didn't over-tighten the bolts. I used to do it by feel until I got a torque wrench, they always leaked some. Last 3 times of pulling the pan and using the cork gasket torqued to the spec ( 18lb-ft? ) no leaks and thats with no permatex or other gasket sealer.
dylan1303
Aug 12, 2015 02:00 AM
BigWil
Mar 29, 2015 12:24 PM
VF-124
Mar 16, 2015 08:14 PM
