tranny fluid leaking out of bottom fitting on case - what to do
Alright just got the 700R4 back in the car, and fired it up.
It's leaking from around the fitting for the fluid lines on the pass. side.
I got a picture to show you better:
http://users.zoominternet.net/~sc93/trannylineleak.jpg
It seems to be leaking out of the front, where the tube goes into the fitting, right around the tube. It doesn't seem to be coming from any threaded areas
should I just lower the trans AGAIN and remove and replace the fitting ???
Magenta_Hearts
Mar 25, 2015 10:24 AM
