Torque Arm Comparison?
Old May 25, 2004 | 03:20 PM
Ekof96Z28's Avatar
Hey guys Im in the market for a aftermarket body mount torque arm.
Ive seen one from Jegs a "Jegster" Body Mount T/A for 93-97 f-bodies.
Ive seen the BMR Trak Pak T/A
and ive seen the Spohn body mount T/A
Has anyone had experience with the Jegs?
Its a bolt in and considerably cheaper... I dont need anything that will take a 10 second pass or anything... Just something that works well enough to run 12s for now.
Any information would be appreciated
-Eric
Old May 26, 2004 | 06:08 AM
Ekof96Z28's Avatar
ttt Anyone used the jegs one at all?
Old May 26, 2004 | 11:24 AM
The areas I would be concerned about, from just looking at the info on the Jegster:
-you will have to tear the carpet out to do the "bolt-in" front mount. The Granatelli was like this, a real PITA.
-the arm uses a "slider" in the front to accomodate the mandatory changes in length as the TA and the LCA's rotate around two different points. Spohn's original TA design was a "slider" and it wasn't really very reliable as HP went up. A lot of people managed to break them. They were repaired or replaced, but the design really wasn't good for big HP. Spohn abandoned that design.
-the 2/3 the length gives 1.5X the downforce is an intersting concept, but as you trade off the length, the lift on the front goes down. You're approaching a "ladder bar" design. Stealth and Madman advocate a "longer" arm. Spohn and BMS seem to pretty much match the factory length. Not sure which is better.... I just know there are people pulling 1.2X 60-fts with the Madman, BMR and Spohn arms. Maybe someone is doing that with the Jegster, so they need to stand up and be counted. The "2/3" length also increases the "shear" on the slider by 50%, so it may make the slider design even less reliable.
Spohn and BMR are proven designs. If you are under 400HP, you could probably get away with the low $$$ arms that simply mount to the stock location on the tranny tailshaft. For higher HP setups, the "body mount" is mandatory IMHO. The Spohn bolt-in is a little more user friendly.
Old May 26, 2004 | 02:36 PM
Ekof96Z28's Avatar
Okay... The reason Im looking at body mount is I decided to swap a th-400 in and begin the cars transformation to all out drag car.
I would probably be better off buying a used BMR or spohn i guess... you bring up some good points about the jegster that I hadnt realized.
Is that why its so much cheaper? the slider design and such?
I guess ive got to think about this some more... the cars got nitrous in its future... i probably shouldnt skimp on anything....
Thanks fred
-eric
Old May 26, 2004 | 03:41 PM
Check my mod's list.... TH400, 300-shot, Spohn TA.
I spend some time helping out on this car.... TH400, 22# Vortech boost, Spohn TA. 1.31-sec 60 ft, 8.76@160MPH.
http://cjcfo.fbody.com/members/injun.../DCP03860a.jpg
http://cjcfo.fbody.com/members/injun.../DCP03870a.jpg
Old May 26, 2004 | 10:41 PM
Ekof96Z28's Avatar
Very impressive. Youve convinced me. SPohn it is.
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
autoxr166
Sep 25, 2015 04:21 PM
Jake Bialke
Sep 24, 2015 11:31 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Bxlt1
Sep 17, 2015 08:31 AM
