Need help on what spline axels to use? (nine inch)
Old May 26, 2004 | 11:09 PM
elec87's Avatar
Okay guys I Was wondering if there is anyone that can give me some insight on how tough or how much power different spline axels are in a ford rear.
Are 28 splines strong at all and what is the limit on them before they break, Can they be used in a stick application?
I was looking at 31 splines but that would require me to get a new center section and axels Is it worth it?
Elec
Old May 27, 2004 | 05:27 AM
IllusionalTA's Avatar
You have a 9" section already? I have 31's in mine and thats the minimum i'd want.. .but a aftermaket set of axles' like moser/stranger should be strong enough in the 28 spline..
Old May 27, 2004 | 06:14 AM
97FormulaWS-6's Avatar
I'm running 33 Spline in my 12-bolt, and in my Nova's 9".
For most applications this is where I'd sit; unless you're in the 4-digit HP numbers.
I'm thinking of upgrading my Nova's rear axle again when I build the motor for it, but that's going to be a Monster Motor/Car at that point, where for my piece of mind I'll go to 35 or 40 spline axles due to the 16"+ wide MT Sportman Pro's out back.
Old May 27, 2004 | 11:41 AM
elec87's Avatar
So go for the 31's then?
Old May 27, 2004 | 08:39 PM
rskrause's Avatar
Moderator
Agree with the above.
For more specific feedback it would help to know how much hp you are making, what gear you are running, and the tire you will be using.
Rich Krause
Old May 28, 2004 | 02:47 AM
elec87's Avatar
Sorry I guess I did leave out the good stuff.
I plan on running a 4.11 the truck is a 6 speed from a 94 z
I have 28x11.5 et streets on it and it should be good for 400 on motor and spray maybe 550?
Z Power
Sep 19, 2015 11:19 PM
rvonsternberg
Sep 14, 2015 11:58 AM
Daluchman1974
Sep 11, 2015 06:12 AM
maverickmk
Sep 1, 2015 09:17 PM
mrwz28
Jul 8, 2015 09:11 PM
