wheel bearings
Old May 21, 2004 | 07:59 PM
spoetzel's Avatar
wheel bearings
my car squeaks when i drive it so im starting with the wheel bearings and i was told there was two bearings per wheel is this true?
Old May 21, 2004 | 08:31 PM
JamesNobles's Avatar
Well depends....are they the front wheel bearings?? If so, then they are sealed and you cant even mess with the bearings!! You have to change out your whole hub....Its not that hard but its not that cheap either. I just had to do that....how is your tire wear, uneven?? Does it pull one way??
james.nobles@jbab.aorcentaf.af.mil
Email me everything that is squeeking or squeeling...and I will help ya out
James
Old May 22, 2004 | 04:04 PM
OBE1 95Z28's Avatar
I's suggest you look at your brakes first for the source for squeeling. Wheels bearings are checked by the amount of play in the wheel when the front wheels are jacked up off the ground. Grab the tire at the 3&9 position and rock back and forth feeling for play. Do the same thing at the 12&6 position.
Old Jun 3, 2004 | 03:40 PM
spoetzel's Avatar
no im doing rear wheel bearing james and thanks for the info obe1
but i am still unsure if the are two bearing per wheel anybody know
Old Jun 3, 2004 | 04:25 PM
spoetzel's Avatar
also i cant figure out how to even get to the bearing........i took off the caliper and undid the bolts on the back side but it still wont budge someone know anything about this?
grabbem88
20
Dec 27, 2015 07:42 PM
akwa
Apr 5, 2015 05:09 PM
warmeck
Mar 8, 2015 08:01 PM
