373 gear down-sides?
Old Jun 2, 2004 | 09:55 PM
Myxtreme1's Avatar
After I get more suspension stuff done I will be adding 373's. What are the down-sides if any to these gears?
Old Jun 2, 2004 | 10:04 PM
GreenDemon's Avatar
You'll run out of gear sooner
Gas mileage may be slightly effected, but if you're not keeping a log, you probably won't notice.
Engine will run higher when cruising, and be a bit louder. Rpms at 75 would be approx. 2700 I think.- If you do a lot of high speed cruising, you may actually notice a difference in mileage. If it's mostly around town or on local highways where you really only go 60, I don't think you'll notice.
Old Jun 2, 2004 | 10:11 PM
blazzinbird's Avatar
i really noticed a loss in gas milage
i use to go 340 to a tank in my 96 t/a a4 but when i put in my 3.73's i can only get 250, of course i drive 80mph on the highway, and i know that is what hhurts it
Old Jun 2, 2004 | 10:49 PM
Spinner's Avatar
I sure like mine.
Old Jun 2, 2004 | 11:28 PM
Camaro_Guru16NY's Avatar
Since your car is and auto you will want to invest in a Torque Converter like 2800 or 3000 stall. otherwise cruising will be absolute hell.
john
Old Jun 3, 2004 | 09:17 AM
Myxtreme1's Avatar
john
How does the stall compinsate the gears?
Old Jun 6, 2004 | 05:17 PM
well, its not really that big of a difference when it comes down to it but you wont have to be idleing at 3500 RPMs when your cruising down the highway at 65 so it does make a little bit of difference.
-john
Old Jun 7, 2004 | 02:25 AM
Ryan's LT1's Avatar
75 = 2500 RPM on the nose. I noticed a huge drop in gas mileage. My friend has stock 2.73 gears in his Z and he gets about 280 to the tank with his A4.. i get maybe a little over 200, with not much freeway driving.
Old Jun 8, 2004 | 03:30 PM
redzsmoked212's Avatar
you guys fogot traction, that gets pretty hard when you launch if you keep steet tires.
Old Jun 8, 2004 | 06:06 PM
aram's Avatar
You run out of gear really easily with 3.73's on a 26" tire.
Old Jun 9, 2004 | 11:32 AM
dang aram you pulled mid 13's with a gtp is that stock? that pretty darn good for a grand prix
Old Jun 9, 2004 | 11:33 AM
ABA383's Avatar
Try 3.42s....Plenty of bottom end pull with the 3.06 first gear, and plenty of top end. 10 years on mine and my sig has mpg...
--Alan
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
naaz90
Jul 27, 2002 08:22 AM
AW/whiteZ-28
Jul 25, 2002 04:09 PM
