Tranmission Swap - Help!
Old May 22, 2004 | 04:58 PM
Z28WannaB's Avatar
My tranmission in my 95' Formula V8 A4 is failing. I know its bad, I had two shops give me estimates. They both said 900-1500 dollars. Well, I figure I will just buy a used one and swap it in myself with the help of a few friends.
Does anyone know how I can go about getting information on how to perform the "swap". I have already searched but was unable to find any information. I have that crappy Haynes book which seems to provide as little detail on topics as possible.
Perhaps there is a sight that covers in-depth the swap of the transmission.
Will a 94' Z28 A4 work in my car?
Any suggestions would be greatly appreciated.
- Z28WannaB
Old May 22, 2004 | 05:47 PM
sc93's Avatar
I just did mine in my 93 twice. It's not that bad, just time consuming. Make sure you have at least a 2 foot long extension for your ratchet, makes it much nicer to get the bellhousing bolts out
Old May 22, 2004 | 09:58 PM
Z28WannaB's Avatar
Did you pull the transmission out from the bottom of hte car?
- Z28WAnnaB
Old May 23, 2004 | 12:35 AM
sc93's Avatar
Yes, I got the car on 4 jackstands, get it as high as you possibly can. The higher, the easier to get the tranny out from underneath.
I didn't have mine quite high enough, so after I lowered it down on the tranny jack, I had to slide it off the jack and onto the ground
Old May 23, 2004 | 03:09 PM
Z28WannaB's Avatar
Well, I am going to have a machine lift so I will be able to get the car pretty high. I am not highly mechanically inclined, however I have changed my brakes, alternator, battery, intake, and a few other simple things. I have a friend who did a motor swap on his mitsubishi eclipse who is gonna help me the whole way through.
About on average how much time does a job like this take?
Old May 23, 2004 | 03:51 PM
sc93's Avatar
R&R at a dealership I think they charge for 6.5 hours of labor.
I had mine out in like 4, in in a little less time
Old May 23, 2004 | 07:24 PM
Z28WannaB's Avatar
Are there any sites that might have a run through of all that will be needed to complete my project?
- Z28WAnnaB
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
