car shaking like crazy help!!!
I recently had a new clutch installed and my pressure plate resurfaced.I noticed after driving the car a weird vibration when pulling of in first gear.All the other gears feel fine but the car still vibrates to the engine.I read about the tranny mount so I installed one hoping to solve the vibration but it did not.The clutch pedal also vibrates as if I can feel the flywheel turning.It seems to be that I created a problem trying to get a new clutch.Any Ideas on whats going on will be greatly appreciated....
Re: car shaking like crazy help!!!
do you mean you resurfaced the flywheel? if not that is probably the problem. generally that has been my experience when a clutch starts to go out. kind of like warped brakes. i've also seen a release brg. fail and cause it also. grasmo.
