T-56 Question
Old Dec 25, 2005 | 07:59 PM
crazypurgatory's Avatar
Question T-56 Question
I found a T-56 for sale and just want to make sure I know what it is.
A T-56 is the six speed manual that comes in Camaro Z28's from 1993 to 1997right?
And it takes auto transmission fluid.
Thanks,
Chris G.
Old Dec 25, 2005 | 09:10 PM
MyShibbyZ28's Avatar
Re: T-56 Question
Thanks,
Chris G.
Yes, a six speed
Used from 93-02, but only 93-97 will fit 93-97, and 98-02 only fit 98-02.
Using auto tranny fluid? I have no clue about that since I don't have a t56.
Old Dec 25, 2005 | 09:36 PM
Thumbs up Re: T-56 Question
Originally Posted by MyShibbyZ28
Yes, a six speed
great thanks for the info.
Chris G.
Old Dec 26, 2005 | 09:36 AM
rskrause's Avatar
Moderator
Re: T-56 Question
Yeah, ATF is the recommended lube for the T56.
Rich
Old Dec 28, 2005 | 03:37 PM
Kurt Crosbie's Avatar
Re: T-56 Question
How come you can't interchange a t56 from an ls1 into an lt1?
Old Dec 28, 2005 | 05:08 PM
Re: T-56 Question
The LS1 shaft is longer.
Old Dec 28, 2005 | 11:50 PM
Re: T-56 Question
Can't you just put an LT1 shaft in an LS1 tranny and call it a day then?
Old Dec 29, 2005 | 12:05 AM
Capn Pete's Avatar
Re: T-56 Question
I believe so . There's an issue swapping LT1 <<>> LS1 4L60E's as well.
Old Dec 30, 2005 | 12:14 PM
Dave '97 Z28 M6's Avatar
Re: T-56 Question
Now that's just what those LS1 guys need... an LT1 guy telling them they have a longer shaft
Chris: Not all T-56's were created equally. The '93s have different ratios (and significantly lower torque ratings as well). Make sure you get a '94-'97 tranny.
There's some info here that might be useful. It's almost halfway down the page.
Old Dec 30, 2005 | 12:22 PM
97WS6SCharged's Avatar
Re: T-56 Question
The transmissions are the same. The bellhousings/flywheels and the clutch actuation are different. LT1 is a pull type, LS1 is a push type.
Old Jan 1, 2006 | 01:49 PM
MR.ED's Avatar
Re: T-56 Question
The front plate,bellhousing and input shaft are different from ls to lt versions. Those 3 parts can be swapped to make an ls into an lt or an lt into an ls version. This does not include all the different clutch stuff. There are 2 different sets of ratios in the 93 boxes with 350 and 400 torque ratings. The 94-97 are a different ratio yet but 450 lbs of torque capacity.
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
Duke
Jul 31, 2002 05:13 PM
