10 bolt girdle stud preload.....
Old Jan 5, 2006 | 07:51 PM
wrd1972's Avatar
Just installed a 10 bolt girdle.
The instructions state to torque the studs to 10 pounds. Here is the problem.
My big torque wrench will to go any lower than 20 foot pounds.
My small torque wrench wont go any higher than 60 inch pounds.
I currently have the studs torqued to 60 inch pounds.
Is this acceptable and if not how do I get the correct torque.
Thanks.
Old Jan 6, 2006 | 07:54 AM
Re: 10 bolt girdle stud preload.....
10 lb-ft seems excessive. The T/A online install instructions recommend 5 lb-ft (the 60 lb-in you have it set at already).
http://www.taperformance.com/rear.htm
If its a different brand, it might have different spec, but 10 lb-ft seem too high.
Old Jan 6, 2006 | 08:38 AM
wrd1972's Avatar
I got the summit racing one which is similar, maybe a bit beefier.
The common sense side of me thought 10# was a bit high too.
Old Jan 6, 2006 | 12:05 PM
remaxracer45's Avatar
I got one from jegs for xmas and it says 10 ft pounds as well
Old Jan 6, 2006 | 01:58 PM
wrd1972's Avatar
I am going with injuneer on this one.
Old Jan 9, 2006 | 07:22 PM
Bud M's Avatar
The instructions with the Mac cover (which may be the same piece as the TA) calls for 5 ft lbs.
96SilverRam
Nov 20, 2016 11:19 AM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
