T-56 problem
Old Dec 26, 2005 | 10:54 AM
chevelles101's Avatar
T-56 problem
Well I think I lost fifth and sixth gear today, but hopefully not. Whenever I put it into either of those gears it just makes a grinding sound. It never went into fifth very smoothly anyway. Can anyone confirm this? And if so is it just the synchros that need to be replaced or is there more? The car is a 95 z a4---->m6 conversion with full bolt-ons minus headers and 105,000 miles. Any input is greatly appreciated.
Old Dec 26, 2005 | 01:55 PM
Re: T-56 problem
any ideas anyone?
Old Dec 26, 2005 | 02:00 PM
wbna0149's Avatar
Re: T-56 problem
Mine did the same thing , it turned out to be bent fork and a couple of other small things.
Old Dec 26, 2005 | 06:29 PM
Re: T-56 problem
thanks for your input
Old Dec 26, 2005 | 06:31 PM
Re: T-56 problem
wbna 0149 how much did it cost to have those things fixed? or does anyone else know how much it would be to fix my problem?
Old Dec 26, 2005 | 11:24 PM
Re: T-56 problem
Ttt
Old Dec 27, 2005 | 10:00 AM
Re: T-56 problem
no one else has any ideas?
Old Dec 28, 2005 | 11:59 PM
IdahoLT1's Avatar
Re: T-56 problem
i read on here that there is a(1) synchro for the 5th and 6th gear, that would be my guess. might not be the hydraulics if it isnt happening to anyother gears. just my input
Thought i would also add that my 1st gear grinds when trying to downshift into 1st while moving and wont go in but when im stopped it sometimes just grinds a little and will go in. Can you put it into 5th or 6th while stopped with the car running? I am in no means a mechanic but this was just my experience and thought it might help.
Old Dec 29, 2005 | 11:45 AM
Re: T-56 problem
yeah i can put it in both 5th and 6th while car is running sitting still or moving but if i release the clutch it just makes a grinding sound in those gears. i pulled the tranny and took it to a local shop so hopefully i will hear back from them later today. ill let you know what they say
james007moore
Jan 1, 2016 01:14 PM
blownxtreme
Aug 26, 2002 03:28 PM
americanbadazz
Aug 5, 2002 11:10 PM
Duke
Jul 31, 2002 05:13 PM
