Estimate Cost of Clutch Replacement?
Re: Estimate Cost of Clutch Replacement?
who's doing the work? if you do it yourself the cost of the clutch, lol. Replacements run from 300-1200 so you can pick and choose there. If your having a shop do it i would guess around $600-800.
Not a huge job, but a lot depends on the local labor rate. The cost of doing business is very high around here, so our shop is at $82/h (at the high end locally). In a non-socialist state, especially in a rural area, you might pay half of that. It ought to be about a 4h job, but to be honest I have never done just a clutch. It's always been in combo with something else. So, a clutch is one of those jobs where the parts are more than the labor. Kind of refreshing in that respect.
Rich
Rich
So how hard would it be to do it myslef? i dont have a lift or anything though
and i believe our labor rate is $40/Hr
but i live in the birthplace of nascar, and all kinds of people know how to work on these cars out here...
Thanks Chase
Thanks Chase
i did mine by myself with a craftsman 137 piece tool kit, 4 -6 ton jackstands and a crappy 2 ton jack, took me 2 days but i wasn't starting untill noon each day and was taking my time, there are some good writeups online, its pretty much removal and reverse. The belhousing bolts ate a pita to get to tho, be prepaired to use multiple extensions and u-joints.
Thanks Chase
Thanks Chase
It's not a hard job really. But it's a hell of a lot easier on a lift with good tools and lighting, etc. If you have a buddy to help, it's owrth a try. OTOH, at $40 an hour, I would say take it to a shop unless you have more time than money. It will take you a LOT longer than four hours, more like 12+ without a lift and with no prior clutch jobs under your belt.
Rich
