How to tell the condition of a m6?
Old Jan 6, 2006 | 07:45 PM
Jazsun's Avatar
Im new to a manual let alone an fbody, I am looking at buying one soon. Its got 46k on it. What should I look for while driving it to tell the condition of the clutch/tans.
Thanks,
Jason
Old Jan 6, 2006 | 08:12 PM
Birdman7389's Avatar
Re: How to tell the condition of a m6?
Make sure it does not grind when changing gears, and make sure it does not "pop" out of gear....
Old Jan 6, 2006 | 11:19 PM
Jazsun's Avatar
If its grinding or poping out of gear does that mean its a clutch or trans problem? Thanks for the headsup. Anything you could tell me would be useful.
Old Jan 7, 2006 | 09:21 PM
96speed's Avatar
Every T56 I've test drove has "growled" when I started in first gear (the more I slip the clutch the less growl it made). Shift through all the gears. Shift fast/hard through the gears. Go WOT and shift. That is the best advice I can give. Don't be afraid to do to the car what you WILL do to the car .
Good luck. Happy LT1'ing .
Ryan
Old Jan 8, 2006 | 04:31 AM
angel71rs's Avatar
Test when warm. I've noticed that the clutch engages/disengages slower when cold on my 98. Can cause grinding going into 2nd. I think it's the hydraulic fluid flowing slowly thru the line to the slave. Haven't done the drill mod yet.
cocopops
Cars Wanted
Feb 1, 2016 06:22 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
SEOJustin
Sep 24, 2015 04:39 PM
