Trans Swap
Old Dec 17, 2005 | 09:14 PM
rg1993ss's Avatar
Trans Swap
I just found a wrecked 1995 Firebird with a 6 speed want to swap out my the burned up auto trans in my 1993 Z28. I belive this tran will work do I need to change the master cylinder. Also do I to pull an wires off the firebird, back up lights or anything else. Thanks Ray
Old Dec 18, 2005 | 02:38 PM
PipesTA's Avatar
Re: Trans Swap
I followed this write-up for my 95. Not too sure if the plugs will be the same or not. Great mod and not that hard to do. Good luck
http://www.afrashteh.com/tranny_pics/T56.htm
Old Dec 18, 2005 | 08:47 PM
rg1993ss's Avatar
Re: Trans Swap
What do you mean by the plugs? Thanks Ray
Old Dec 18, 2005 | 09:02 PM
Birdman7389's Avatar
Re: Trans Swap
When you pull the trans, make sure you get any of the plugs that are on the trans, with a length of wire still attached. Otherwise you have to buy them from GM.
You will need to get the master/slave, pedal assembly, crossmember, console, flywheel.......Just take a good look at the guide posted.
Old Dec 19, 2005 | 09:09 AM
cwaldt's Avatar
Re: Trans Swap
The wiring harness for a automatic has one connector and the wiring harness for the 6 speed has three connection points. I think you'll have to change your whole engine/trans wiring harness for this to work.
Old Dec 19, 2005 | 09:22 AM
PipesTA's Avatar
Re: Trans Swap
If you just have the three connectors, you'll be able to splice into your existing harness. You'll need a tune taking your PCM from A4 to M6 since your speedo will be way off.
Old Dec 19, 2005 | 04:34 PM
rg1993ss's Avatar
Cool Re: Trans Swap
I have a complete 1995 firebird with a 6 speed and all the wires and connectors. Also I just looked under the car and I though that the 93 had a vacume modulator on the trans, but I can't find it. Thanks for the help Ray
69z-28
Jan 29, 2016 10:46 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
ddr698
Jan 9, 2015 10:05 AM
