No 3rd Or Od-
Old Dec 19, 2005 | 04:48 PM
tookster's Avatar
No 3rd Or Od-
Can Anyone Please Tell Me If They Have Had This Problem. I Just Got This Car, Got On The Interstate And Put The Cruize On, And Everything Was Fine Until I Kicked It Down To Passing Gear And It Sounded Like The Rev Limiter Kicked In So When I Let Off And It Got Back To Speed There Was No 3rd Gear Or Overdrive, Had To Drive Home With Only 1st And 2nd. This Is The 98 Z28 Ls1, With The 4l60-a4 I Think???? We Have Since Taken It To A Trans. Repair To Put It On The Tester And Got No Reading As To Anything Wrong, Is Something Just Stuck Or Broke// Please Help.
Old Dec 19, 2005 | 05:18 PM
corbraeater's Avatar
Re: No 3rd Or Od-
it might be the governer gear, it broke on my 84 camaro 700-R4 and it wouldnt shift out of 2nd,so you might want to check that.
Old Dec 19, 2005 | 05:38 PM
tookster's Avatar
Re: No 3rd Or Od-
Thanks, But From What I Am Hearing, This Trans, Is All Electronic, No Governor, That Was My First Thoughts Until I Did Some Research. I Am Hearing About The Speed Sensors And Solenoids, But I Really Want To Hear From Someone Who Has Had The Problem So I Will Know Where To Look
Thanks For Your Reply.
!!! I Miss My 69 Ss 396 Camaro !!!.
Old Dec 19, 2005 | 06:09 PM
Capn Pete's Avatar
Re: No 3rd Or Od-
Well, the 4L60E is just a fully electronic version of the 4L60 (or 700R4) ... anyway, the tranny in our old truck ('89 Chev, 700R4) went out, lost 3rd/4th gear, but 1st/2nd still worked. Simple answer, tranny was cooked. I don't know if your tranny can be saved by a "quick fix" at this point?
How many miles on your car anyway?
Old Dec 19, 2005 | 07:05 PM
tookster's Avatar
Re: No 3rd Or Od-
97,300. I just traded a 72 chevelle for it, and did not make it 2 miles and when I kicked in in passing gear it lost 3rd. and od.??? but I got the car for my Wife and she is happy with it if I get it fixed, I have several other classics and projects I am working on and now I have a trans. problem to deal with, lol, lol.
Old Dec 20, 2005 | 11:10 AM
MyShibbyZ28's Avatar
Re: No 3rd Or Od-
It is not the bands, you'll be happy to know (that's a complete rebuild).
Sounds like solenoids to me. If it was a band you would either not have 1st and 3rd, or not have 2nd and 4th.
Solenoids actuate the gear to change. The computer tells 1 of 2 solenoids to either turn on or off. If I remember right this is how it works.
1st gear.........solenoid 1 on
2nd gear.........solenoid 1 off, solenoid 2 on
3rd gear.........solenoid 1 and 2 on
4th (OD).........solenoid 1 and 2 off (fail safe mode)
I am sure that is right. Anywho, something might be up with both the solenoids turning on at the same time. I remember someone else had this same problem in a corvette. Changing them seemed to fix it. But the solenoids might be something to look into.
So you cannot even manually go into 3rd? What about just putting it in OD and letting it switch on its own?
Old Dec 20, 2005 | 11:42 AM
rskrause's Avatar
Moderator
Re: No 3rd Or Od-
I'd take it apart and do a rebuild if it were mine. At least replace all the soft parts and anything else that's broken or worn out. Not that hard to do yourself or if that isn't your thing not too expensive either. Maybe $600-800. This book is a big help if you want to DIY. http://www.phoenixhardparts.com/inde...WPROD&ProdID=8
Rich
Old Dec 20, 2005 | 12:04 PM
12SCNDZ's Avatar
Re: No 3rd Or Od-
The 3-4 clutches are out of it...It's a common problem in the 700's and 4L60E's.
Frank
Old Dec 20, 2005 | 12:10 PM
12SCNDZ's Avatar
Re: No 3rd Or Od-
Originally Posted by MyShibbyZ28
It 1st gear.........solenoid 1 on
Um...Where'd you get this info? It's not correct.
1st gear is both "A" and "B" ON
2nd has "A" OFF / "B" ON
3rd is both "A" and "B" OFF
4th has "A" ON and "B" OFF
Frank
Old Dec 20, 2005 | 12:14 PM
Re: No 3rd Or Od-
Frank
Oh, my bad. Thanks for clearing that up!
Old Dec 20, 2005 | 04:02 PM
Pro Built Automatics's Avatar
Re: No 3rd Or Od-
It could be as Frank stated, that the 3-4 clutches are gone, or you could have broken the lugs in the input drum that retain the snap ring holding the 3-4 clutches. This does happen once in awhile.
Old Dec 20, 2005 | 05:07 PM
Capn Pete's Avatar
Re: No 3rd Or Od-
Regardless, doesn't sound good!
Old Dec 20, 2005 | 05:50 PM
tookster's Avatar
Re: No 3rd Or Od-
well thanks for all your help, I am going to drop the pan and see whats up in there, as a friend told me his car did that and he finally sold it just to find out that the solenoid had broke off in the pan. so I hope mine is that way. will let you know in a couple of days, meanwhile please keep what info you have on this coming. thanks.
David Dempsey
Mar 12, 2016 12:42 AM
WobblySausage
Oct 7, 2015 10:09 AM
Girrrrl
Aug 20, 2015 09:26 AM
Girrrrl
Aug 20, 2015 06:17 AM
Boss002
Jul 24, 2015 10:47 AM
