2.73 or 3.23
Old Dec 18, 2005 | 07:22 PM
cn97z28's Avatar
2.73 or 3.23
I have a 97 z28,was looking for gear #'s on it, any ideas where to look? Owners manual said to look in the console, nothing there.
Old Dec 18, 2005 | 07:24 PM
2000GTP's Avatar
Re: 2.73 or 3.23
Mine are located in the drivers side door jamb and I got a 97 also.
Here is the breakdown:
GU2 Axle, Rear 2.73 Ratio
GU4 Axle, Rear 3.08 Ratio
GU5 Axle, Rear 3.23 Ratio
GU6 Axle, Rear 3.42 Ratio
Old Dec 18, 2005 | 07:28 PM
6SpdLT1Z's Avatar
Re: 2.73 or 3.23
3.23s have "1" on the shifter.
2.73s don't.
Old Dec 18, 2005 | 07:51 PM
1badasZ's Avatar
Re: 2.73 or 3.23
2.73s don't.
that too but the label should be in the glove box
Old Dec 18, 2005 | 08:29 PM
Birdman7389's Avatar
Re: 2.73 or 3.23
3.23's can select 1st gear, 2.73 can't.
Just trying to help, along with checking your RPO codes.
Old Dec 18, 2005 | 09:00 PM
Andrew R's Avatar
Re: 2.73 or 3.23
That can be fixed
Old Dec 18, 2005 | 09:43 PM
6SpdLT1Z's Avatar
Re: 2.73 or 3.23
Originally Posted by Andrew Rhines
That can be fixed
yeah but it will still have 2.73's.
Old Dec 18, 2005 | 10:32 PM
cn97z28's Avatar
Re: 2.73 or 3.23
There is no label in the glove box..
Old Dec 18, 2005 | 10:36 PM
fesgali's Avatar
Re: 2.73 or 3.23
Look on the information on the driver door.
Old Dec 18, 2005 | 10:37 PM
cn97z28's Avatar
Re: 2.73 or 3.23
Found it GU2... 2.73 ...
Old Dec 19, 2005 | 02:32 AM
Camarocracy's Avatar
Re: 2.73 or 3.23
I know how you feel, my Formula has the same gears
Old Dec 19, 2005 | 03:26 AM
Schweet97Z's Avatar
Re: 2.73 or 3.23
im putting 3:73's in pretty directly.....its going to be a drastic change! i cant wait 2:73's to 3:73's
Old Dec 19, 2005 | 06:04 AM
6SpdLT1Z's Avatar
Re: 2.73 or 3.23
sorry.
Old Dec 19, 2005 | 09:14 AM
cn97z28's Avatar
Re: 2.73 or 3.23
Why GM even bother putting in 2.73's if they suck?
Old Dec 19, 2005 | 12:50 PM
Capn Pete's Avatar
Re: 2.73 or 3.23
I've had 2.73's, 3.73's, and 4.10's in my car. 2.73's aren't "The Devil" that people make them out to be. The only time they seem to suck is initially off the line. On the highway, they rock. Maybe they just complement the power band of the LS1 better though?
BTW: only LT1 cars blocked of 1st gear w/2.73's. My LS1 w/2.73's CAN go into 1st gear right from the factory. That wasn't just a screw up either! They're all like that.
