driveshaft question
Old Jan 5, 2006 | 11:45 PM
silver30th's Avatar
driveshaft question
is it true that you can use an ls1 aluminum driveshaft with a lt1 car? i swear i heard it somewhere once before, so please dont flame.
Old Jan 6, 2006 | 06:33 AM
Capn Pete's Avatar
Re: driveshaft question
Yes you can . AFAIK, all driveshafts are interchangable from '82 to '02 . Lots of guys run the LS1 aluminum. If you're looking around for one though, watch out for the A4's w/2.73's ... you'll find a nice steely in them.
Old Jan 22, 2006 | 12:01 AM
creed1062002's Avatar
Will the autos and manuals interchange?
Old Jan 22, 2006 | 12:14 AM
194bird's Avatar
yes they will what exactly are u looking for i have 2 steel shafts
Old Jan 22, 2006 | 12:21 AM
I have a bad vibration i am thinking it is the driveshaft. had the tires rebalanced today. Anywhere over 60 it vibrates more so when you let off the throttle but also when you are accelerating. I was looking for a replacement driveshaft to put in to see if it is indeed my problem
Old Jan 22, 2006 | 11:08 AM
194bird's Avatar
sounds like it is your problem that is what mine did i put a 9 inch in mine so i had to change the rear joint did that had no problems decided next time i had it out to repl the front joint with a heavy duty put back in hello vibration if so i had a hole new nitrous ready shaft made was told when i had that one made that all factory drive shaft are a little out of ballance and when you change somethig look out
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
blac94Z
15
Mar 2, 2015 12:00 PM
ddr698
Jan 31, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
