- tranny crossmember
- 97 LT! into a 89 bird
- supercharger???
- need help picking my next 3rd gen
- louvers smashed! aahhhhhhhhhhhhh
- can a vortec 350 be put in?
- What rear end?
- Steering Issues
- sportlines with headers?
- headers
- another 700 question
- Ticking noise in front end
- 58mm TB?
- Pushrods
- caprice, monte, celebrity headlight swap
- 18" rims on a 3rd gen
- chip interchange
- Cluster issues....
- some questions on my header and driveshaft purchase.
- 700R4 question
- Knocking problem and codes
- Throttle body ?s
- New fuel injectors fixed several problems
- my exhaust is getting me stoned.......
- Rocker Arm Question
- The Beast is out! *PICS*
- whats the best 4th gen seat
- possible to pull motor and tranny without unbolting,bout to do it need help now!!
- fog light question
- burning a chip
- MAF upgrade
- shifts too soon
- I'm gettng a 85 Z28!
- couple quick, stupid questions
- type of rearend to buy?
- HELP! Starting problem on 90 RS 305TBI
- New injectors installed, now backfires, won't hold pressure!!
- aklim hsr fuel lines
- what kind of gas is best? regular or premium
- TPI to Carb
- V6 to V8 Question
- Fuel injector wires installed correctly?
- Carborator
- Breakdown
- Fan Switch still not working
- Running Lights/Parking lights are out!
- Carb conversion
- I just got my fan control kit and I'm lost..any electrically gifted people out there?
- when doing a t56 swap.
- a dream and an oil leak.
- T56 swap causing code 24?
- got new shocks/struts/springs on a budget
- hedman longtubes
- Can a TPI with this many miles handle this?
- lt1 intake gains on 305 with stock heads
- Best cam for HSR
- should an exhaust leak pop?
- Do I Have Posi?
- Trouble Codes
- weird problem
- Wiring Problem
- want to charge my l98
- out with the old in with the new(sorta)
- Boring a 355-cost/size?
- Need advise for my 3rd gen friend
- Driveshaft question
- edlebrock torque arm
- Chip for 305 to 350
- how is vacuum important?
- radiator
- cam selection help!
- Really Need Help Fast On A Ramjet!!!
- Fans again
- A/C Conversion kit
- will fourth-gen seats mount easily in 3rd
- black headlight pockets?
- Subframe connectors question
- ECM Conector
- Fan control (via a relay) and idle on carbed 350
- Engine will not crank
- determine injector size?
- Broke water neck bolt, now what?
- Difference between T-5 and T-10
- links and pics of big block 3rd gens
- Header/Y-pipe/Cutout Combo?
- '82 Z28 exhaust question
- Where can I find a 305 H.O. air cleaner?
- Yet another brake upgrade available!
- 3rd Gen Posi Unit
- Another Basic Camaro Question
- Water Pump
- Harmonic balancer.
- Running Rich....Bad Computer?
- Just made some purchase's
- What is this thing???
- Mini High Torque Starter
- Flame throwers?!
- Which gaskets?
- Code 34
- Damper for engine
- 305 TPI to 350 TPI
- torque converter questions
- Head Porting
- Wich Intake Manifold?
- Make my ride smoother
- how bout this cam
- battery mounts
- Traction Bars VS. Lift Bars
- Basic Camaro Question
- what heads
- Lost oil pressure
- New Car for me :)
- Exhaust Pipe Diameter on 90 305 TPI
- hitting up my ugly rims with tal strip and sand paper , some adivce needed
- At what RPM does the beastly LG4 make the most torque and horsepower
- none of my guages work...
- car turns over but won't start, help me please!
- aftermarket Parts
- Bad valve seals,does lucas stop the bleeding
- what was the tranny called in the 92 camaro's?
- distributor tunning question!
- Rattling noise and check light...
- build me an engine that....
- Vortec rocker arm stud
- What RPM should an A4 tranny shift at?
- What is this part called?
- Installing a Cutout...
- Back of egr solenoid
- Y Pipe
- Which is better, going to a LS1 or Lt1?
- Couple questions for the experts...
- having major problem
- extra vacuum lines
- billet wheels
- info on superchargin a 350
- Headliner repair
- carb to injected??
- Spare tire
- L-98 carb ?
- Daul Cooling Fan conversion
- Important Question!!!
- Speedo & new gears
- Overheating?
- Exhaust Opinions...
- Got a problem
- Ramjet Vs. Mini-RAM 3
- New Cam Yay!!!
- 335 C.I. Stroker
- Changing Auto to a Manual,HELP!
- Free or DIY Mods
- Test fuel injectors and fuel regulator out of car?
- Where are the Iroc part sites?
- HSR vs. miniram vs. superram and N/A or boost?
- Cam, Heads, Intake Combo
- Torque specs for waterpump?
- failed emissions
- No headlights, radio or hatch release, HELP!
- stock irocz rims size?
- Car Running Rich
- Now whats wrong?
- why so why so
- Where to get fuel injectors?
- Vacuum line on a 305 TBI
- Can't get the spring of my door back in!
- Why so much carbon buildup in the intake?
- Brake line fittings
- Thats it!, I give up! just came back from the track
- so check this mess out
- Problem running secondary fan before primary?
- Any thermostat switches turn on @ 185*?
- What different colors of RTV silicone gasket maker
- Manually cranking the car?
- Fan Question...
- new pipe
- New best with my TPI.
- Exhaust on my 84 Z-28
- cheapest way to get 500 Hp out of a 406?
- switching rearends
- pics of 4 inch cowl hood on a 3rd gen
- Hypertech Fan Switch
- moody tranny seal
- Spohn Torque Arm Q's
- Sporadic timing?
- im so damned disgusted with my camaro
- Should i buy this Iroc
- Few purge canister questions
- Where to buy PVC hose and EGR vacuum hose?
- AHHH CRAP! Not another problem... =\
- Which one is the CTS?
- Lingenfelter box and wipers
- Intake Question
- what is the best distributer & wires for an 84Z
- Oil keeps leaking from oil filter
- dist. trouble
- what can anyone tell me about the 82 pace car?
- alternator bracket on edelbrock intake
- HELP i NEED SOME 295/50r16'S
- What the hell is that noise?
- 383 stroker
- Ticking sound from IAC?
- lt1 in thirdgen
- clutch master cylinder
- couple of thins i noticed during oil change
- changing brake pads
- 1982 Indy pace car for sale
- LS1 swap
- DESPERATE FOR HELP! 86-87 TPI owners, EASY question
- t-top compatibility
- S10 axles fit?
- What causes a pig rich condition?
- Bad to remove the MAF screen?
- Where to get GM weather pack connectors?
- 1990 Iroc... good or bad?
- Vette Heads and Cam
- what can i do??
- Do I really need a thermac?
- Do tachs break?
- Loose steering
- 86 Iroc info needed
- Quick LT1 Heads question
- Clear flood mode?
- aftermarket computer chip
- need help
- Cracked Flexplate
- Do i need to pull motor to install headers
- AFR Heads
- t56 tranny
- puttin and knocking sound
- How to set timing after new distributor install?
- Push rod length question
- Help me diagnose this please
- TBI to LT1..fuel pump ?
- Loud Ticking coming from Harmonic Balanceor.
- where to find a MAF
- 3:42 gear swap question?
- Shift bulb by the shifter
- highflow cat
- TPI to Carb swap
- Ahh Darn
- What sensor is this?
- new pads and rotors brakes still soft
- Finally got some pics of my 3rd Gen
- carb jets/rods
- hp rating
- cant find correct headers
- What is this connector to?
- Where does this ground strap connect to?
- what do original floormats look like?
- accel header plugs
- how damaging is brake fluid (on tires, wheels, body)
