Mini High Torque Starter
Old Apr 26, 2004 | 10:09 AM
r4mbler's Avatar
I recently dropped a 327cid in my 86 z28. The Problem I am having is The oem starter doesn't have the, how can i say this ump to turn the engine. I have been searching the net for mini high torque starters but have not found exactly what i need. also it has the stock 5 speed. I was wondering if anyone would have a recommendation, is where a person could get a good starter to fit what i have. Thanks for ya'lls time..hehe
Old Apr 26, 2004 | 10:27 AM
r4mbler's Avatar
no recommendations?
Old Apr 26, 2004 | 10:40 AM
trackbird's Avatar
Try any of the mail order guys. Jegs, Summit, etc should be able to fix you up.
Old Apr 26, 2004 | 10:45 AM
aklim's Avatar
I have been very happy with my GMPP High torque starter which I got from the GM Parts department.
Old Apr 26, 2004 | 10:58 AM
r4mbler's Avatar
Probly just need to call summit or jegs have them find what i need. thanks for the info guys.
Old Apr 26, 2004 | 12:04 PM
r4mbler's Avatar
1000 amps should crank it over pretty fast right? plus had truck jumping it off just to make sure a couple of times. not sure the comp raito. my father built the motor for me. what i do know is i have a bore of .20 over flat top pistons double "camel" humped heads with 202 valves triple valve springs. steel standard 327 crank. 3/4 cam....
if you can figure the comp. raito that would be great. i dont know it. my father may.
Old Apr 26, 2004 | 12:50 PM
aklim's Avatar
Call Air Flow Reserach and they might be inclimed to help you. The have programs for figuring this sort of thing out. BTW, what size dome in the heads? You need to know that too.
BLK1997Z28
May 7, 2015 03:01 PM
lt1matt
Mar 21, 2015 07:35 PM
Jason Short
Jan 19, 2015 06:34 PM
Jeff1904
Jan 3, 2015 12:00 AM
