what kind of gas is best? regular or premium
If it isn't pinging it will make the same (or more) power with the lower octane. The octane rating is the gases resistance to detenation, which means a heavier (thicker) fuel. 87 octane actually has more energy than 93 octane, but you will probably have detenation running it and the computer will pull timing making it produce less power.
Botch
Botch
Botch
Botch
Much better gas mileage from running higher octane? That's a new one on me
I have my 85 owner's manual, and there's no mention of the need to run higher octane gasoline for the TPI cars.
if thats true then i leaned something new, i also diddnt know that you should run the lowest octane you can, well i know that for anyones wallet thats ussually the best to not run more then is needed, but i diddnt know you actually will get more power, interesting
The BTU energy in 87 is the same as 92. Octane is the fuels resistance to detonation. It has nothing directly related to performance. If an engine doesn't detonate 87 octane then using 92 won't increase the performance.
As mentioned above, use the lowest octane that won't cause detonation.
Originally posted by PyRo9862
You can advance the timing, and run a higher octane and gain a couple hp cannot you?
I used 93, but they I discovered my timing was advanced a few degrees, and I set it back. Now it runs fine on 87
Heck with the money I save I could afford to blow up the motor and replace it because i'm using lousy gas
Originally posted by Pasky
I always try to run premium,simply because I get a heck of a lot better gas milage.
When I bought my 2002, it didn't run as I thought it should. So, guessing the dealer put 87 octane in it, I used 89 on my 2nd fill up. It was better, but not great and the fuel mileage was less than expected (who reads the book?). So, I switched to premium, the hp seemed to be where it belonged and fuel mileage came up even more (around town). Also, my 2002 Z will just "rattle" (knock) like mad at full throttle with anything less than premium in it. But my 3rd gen didn't have that problem. I do get better mileage around town on premium in the new car. However, I was going on a road trip once and the gas station was out of premium. Since I'd be cruising at part throttle on the highway, I stuck 89 octane in it. At part throttle, you won't see enough cylinder pressure to detonate and I got 27+ mpg with the cruise control set at 80 mph (it's an M6). As long as you keep it out of detonation, octane is unimportant.
Did any of that make sense? (it did as I typed it, but I'm not so sure now).
