extra vacuum lines
Old Apr 23, 2004 | 01:28 AM
350TPI5SPEED's Avatar
extra vacuum lines
is there any where to find a vacuum diaghram?? i have 2 extra lines and 2 extra holes, and no they dont go together
Old Apr 23, 2004 | 12:07 PM
WhiteKid's Avatar
Re: extra vacuum lines
This might help me too ^^^Bump^^^
Old Apr 23, 2004 | 12:09 PM
WhiteKid's Avatar
Actually I found this already...haha
Vacuum Lines on TPI
Old Apr 24, 2004 | 12:03 AM
THANK YOU VERY MUCH THIS WILL HELP ALOT
Old Apr 24, 2004 | 12:30 AM
OK I looked at the diagram and the line from the throttle body does not go all the way to the egr sol. and the one from the egr valve does not reach the sol. either. the egr sol. is where the stock coil goes right? i have and edelbrock lower manifold and runners obviously stock upper plenum and a bbk 58mm throttle body, you guys have anything??? im stomped and dont want to route the lines wrong. thanks again
Old Apr 24, 2004 | 12:50 AM
WhiteKid's Avatar
ok i think the throttle body valve and the egr valve both go to the sol. the short one to the egr and the long one to the throttle body
Nellsw88
May 26, 2015 05:55 AM
Patrick Kovack
Mar 8, 2015 09:26 AM
grgguy
17
Feb 23, 2015 07:57 PM
