Loud Ticking coming from Harmonic Balanceor.
Old Apr 13, 2004 | 08:42 PM
Rage's Avatar
I have a very loud and annoying ticking sound coming form the harmonic balenceor I can spray the back of it w/ WD-40 and the sound immediately goes away, and then comes back the very next day. Any suggestions. im puzzled on this one.
Old Apr 13, 2004 | 08:51 PM
aklim's Avatar
Assumint the bolt is tight, it might be a warning that the balancer is going south. When I get a new balancer, I put a mark on it so that when it slips, I can see it. It is basically a metal band over a bunch of rubber on a wheel. I line it up so the outer band and the inner wheel have a mark. When the band moves off the mark on the wheel, I know it is bad.
Old Apr 13, 2004 | 11:01 PM
BigDaddyWiz's Avatar
i had a harmonic balancer go on my old jeep. it was making this sort of ticking/squeaking noise and i noticed it was just brushing up agains the engine. i caught it in time before any damage was done, but i when i sprayed oil it went away for a little while like yours.
Old Apr 14, 2004 | 01:15 AM
aklim's Avatar
Being over the net, I would suggest you get a professional do diagnose and confirm it before you get a new balancer. If it comes out on the road and hits the radiator, well......
Old Apr 14, 2004 | 03:38 PM
Rage's Avatar
How would I perform the diagnosis myself? Also, how much does a balanecor costs? Would you get one at a pick-a-part or definately go new?
Old Apr 14, 2004 | 08:05 PM
aklim's Avatar
You could get a GM one pretty cheaply. I wouldn't get a used one. Since the fancy ones are around $300 I would think that you could get a decent one for under $200.
Red_94Formula
Mar 7, 2015 09:21 AM
importkiller94
Jan 17, 2015 09:03 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
bfmv13trivium
Jan 14, 2015 09:57 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
