383 stroker
Old Apr 16, 2004 | 07:26 AM
redlined4816's Avatar
383 stroker
Does anyone know about a price range it would cost to build a 383 stoker, putting good heads , cam, ect...I just want to get an idea of how much it would cost me.
Old Apr 16, 2004 | 07:47 AM
OldSStroker's Avatar
Re: 383 stroker
"How fast do you want to go?" still applies. Bigger hp and torque and rpm costs more. Without some defined goals for performance, driveability, reliability, any money estimate would just be a "rectal extraction". If "good heads" run $1500-$2000, I'd figure at least double that for a basic 383 engine if you are very good at assembling engines, and have a good core engine. You are only looking a parts and machine work costs there.
You might try contacting a couple of engine designers/builders for an estimate based upon your goals. IOW, tell them where you want to go and let them figure how to get there.
That doesn't answer your question specifically, but IMO you should probably think over $5000 rather than under. There's almost no upper limit if you are going for mega power.
My $.02
Old Apr 16, 2004 | 09:16 AM
hotcamaroprince's Avatar
I'm currently building up my 94 Z to be a 383. I spent $ 1700 on the heads alone (AFR), and have a complete pricelist put together by my knowledgeable friend -- if you want a peek at it, let me know and I'll send it over. I'm going with all forged internals on mine which adds about $750 right there, but it's good for the reliability factor - I don't want to have to do it again in 1-2 years. A good estimate (always estimate high if possible) is $ 2,000 for the heads, $ 4,000 for the upgrade parts, $ 750 for a good clutch if you have a manual, or $ for a torque convertor in an auto... and then maybe other little upgrades that may be helpful like a bigger oil pan and better drive shaft and such. Then add in labor! Sounds like a lot of money but if it's done right and if you can get some help on it, it should run very fast and last a long time for ya. Good luck!
Old Apr 16, 2004 | 10:21 AM
You should be able to get this answered on 3rd Gen Tech.... should be many people there who have done it. Moving to 3rd Gen Tech.....
Old Apr 16, 2004 | 01:38 PM
thanks for the info
Old Apr 16, 2004 | 10:45 PM
97WS6SCharged's Avatar
I've already spent close to $5k on my turbo 383, and I don't even have the motor assembled or a turbo.
You could easily build a pretty stout 383 for what I've invested already. I just go way overboard on my projects.
Old Apr 16, 2004 | 11:06 PM
aklim's Avatar
Back in 96 I spent 5K for an assembled shortblock. I sent them the heads, cam, timing cover and oil pan and they made sure everything was clearenced for it. It was done at LPE.
Old Apr 16, 2004 | 11:28 PM
Black6SpdTA's Avatar
Like everyone said, how fast ya' wanna go? You could put that $800 EBay kit in, and "technically" have a 383. Granted it would run like crap and probably not be reliable, you'd still have one. Name your power goals.
Old Apr 16, 2004 | 11:42 PM
Thanks for all the info, i think im just gona go rebuild my motor, or buy a crate motor, it looks like to get what i want out of the 383 is out of my price range right now
Old Apr 16, 2004 | 11:52 PM
What do you want out of the 383? You can build a budget 383 that will perform and be a good daily driver. Or, like those of us who are nuts, you can go all out and spend a fortune.
Old Apr 16, 2004 | 11:56 PM
ha i wish i could spend a fortune on the motor but the rest of the car needs to get finished too, i wanted like 400-450 hp, around there somewhere
Old Apr 17, 2004 | 12:04 AM
That would be no problem for a budget 383. All your power comes from the heads, so that's where you don't want to get cheap. You could use the SCAT cast stuff or the Eagle ESP stuff and build a really nice 383 for street use.
Old Apr 17, 2004 | 01:00 AM
aklim's Avatar
If the rotating assembly is balanced nicely you could support 500HP on a cast crank with forged pistons and recon rods and a 2 bolt main block.
Quickss96
Jan 29, 2016 05:56 PM
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
alphaauto
Jul 26, 2015 04:40 PM
