couple quick, stupid questions
Old May 1, 2004 | 05:19 PM
TAChad's Avatar
I dont know jack about 3rd gens...but i was wondering what fuel pressure and size injectors are in a 90 350 TPI? I did a search and i think they are 22 lb/hr and 36 PSI?? is that correct?
The reason i ask is i was wondering if my stock 24 lb/hr LT1 injectors will work in my friends car..i know they are bigger injectors, but there is also lower fuel pressure on the TPI, I think LT1's have around 45 psi stock if i remember right.....i was thinking it might equal out. Thanks for your help
Chad
Old May 1, 2004 | 05:30 PM
krazzycowgirl's Avatar
Yes Stock LT1 injectors will work in a tpi car.
Old May 1, 2004 | 07:06 PM
Marc 85Z28's Avatar
The 350 injectors are 22lb/hr, and are rated at 42psi stock. However, in the real world the actual fuel pressure measured at the rails can vary by several psi. Psi is not determined by the injectors BTW, that's what the fuel pressure regulator is for.
Old May 2, 2004 | 07:53 PM
TAChad's Avatar
Thanks for the info. I wasnt concerned about if the injectors would work (as in fitment) in the car, but more if they would be comapatable with the stock computer tuning for the factory injectors for the TPI.
Chad
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
ChrisFrez
Jan 4, 2015 08:43 AM
cmdeshon
Dec 27, 2014 10:06 AM
ChrisFrez
Dec 15, 2014 03:09 PM
