chip interchange
Old May 3, 2004 | 05:54 PM
rottonj's Avatar
chip interchange
Does anyone know for sure if a chip from a 1989 camaro 350 tpi will work in a 1988 formula 350 tpi. Thanks
Old May 3, 2004 | 06:22 PM
krazzycowgirl's Avatar
Didnt they go SD in 89? or was that 90?
Old May 3, 2004 | 10:10 PM
TheGreatJ's Avatar
It was '90. '88 and '89 should interchange just fine IIRC.
Old May 3, 2004 | 10:13 PM
OK then ya they should be interchangeable.
Old May 3, 2004 | 11:27 PM
f-bodybuilder's Avatar
Didn't they elliminate the 9th, cold start injector in 89?
Old May 3, 2004 | 11:41 PM
Oh Chit I forgot. but it should still work. Everyone tells ya that an 89 is the chip you use if you are putting a HSR in a 88 or 87 Iroc.
Old May 4, 2004 | 01:08 AM
aklim's Avatar
My car was a 91 with an auto and it had a 4 letter word stamped on it. Mine was AUJP. If your old one matches the new one, it is safe to use.
I believe 88 and 89 were both MAF. If they eliminated the cold start injector, won't the ECM be expecting more fuel when starting? That might make cold starts a little harder.
HibachiZ28
Nov 6, 2015 12:53 AM
Henson071
Sep 18, 2015 04:01 PM
92_RS_305
Sep 8, 2015 07:47 PM
Slayer
Aug 17, 2015 03:55 PM
whitehooptie
Jul 22, 2015 10:25 PM
