Rocker Arm Question
Old May 2, 2004 | 10:06 PM
aklim's Avatar
Rocker Arm Question
If you have AFR 190 heads and they have guideplates on them, I would suspect you would run the non-self-aligning rocker arms, right? Could you run the self-aligning ones instead? What if you had guideplates and ran self-aligning ones? Would it work? TIA
Old May 3, 2004 | 03:59 PM
Z28SORR's Avatar
You can not run both! If you keep the guide plates when use the non-selfaligned rocker. Otherwise remove the guide plates and use the selfaligning rockers.
Old May 3, 2004 | 10:04 PM
TheGreatJ's Avatar
You can run them both, but it won't last long. The rockers and the guideplates will basically be fighting for control and one or the other is eventually going to lose.
Old May 4, 2004 | 11:56 AM
Z28SORR's Avatar
Oh, and if you run guide plates it's recommended that you use hardened push rods.
1775.Z28
Jan 11, 2015 10:51 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
thenewkid
Nov 27, 2014 09:41 AM
newby
Jul 25, 2002 03:22 PM
