Subframe connectors question
Old Apr 27, 2004 | 09:33 PM
Black91Z28's Avatar
How hard is it to install subframe connectors when you have aftermarket headers with an aftermarket y-pipe?? The reason i ask is because i thought i read/heard from somewhere that they are made for the stock exhaust setup with the dimensions and all. Well i have an exhaust with y-pipe, etc. and i was wondering if there would have to be modifications done to my exhaust in order to fit the subframes on there....
Thanks,
Eric
Old Apr 27, 2004 | 10:17 PM
KnightRider350's Avatar
I have stock exhaust and my spohn subframes don't fit... I'm getting headers/y-pipe in order to get around it. :P Depends on manufacturer.
Old Apr 27, 2004 | 10:27 PM
aklim's Avatar
I have SLPs and am using Alston SFC and they bolt in just fine. The headers go into a Random Tech cat and then 3 in SLP exhaust pipe. Actually welded in.
Old Apr 28, 2004 | 09:10 AM
87DJP2001's Avatar
SLP 1 3/4 Headers and SLP 3" Catback exhaust and Installed Spohn tube type SFC's . The only Problem was I had to remove the heat sheild from the Cat. And that was covered in the instructions from Spohn. Best upgrade I made on my car. Tighter now then when it was brand new (original owner of 1987 IROC-Z).
Old Apr 28, 2004 | 05:15 PM
lordmetalz28's Avatar
we couldnt clear my exhaust either, so we put on one side for now, have to do the same and get headers and custom y pipe to fit the other.
Old Apr 28, 2004 | 07:05 PM
I wish I knew if the hedman y-pipe would clear... Still debating if I want to go hedman longtubes or shorties... the longtubes'd be an even bigger pain in the ***, clearance wise...
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
QuickSilver02
Apr 7, 2015 11:12 AM
Jibberish18
Aug 28, 2002 12:46 PM
