Do I really need a thermac?
Old Apr 15, 2004 | 02:42 AM
transxtreme's Avatar
Ok fellas. I replaced my stock air cleaner with a Edelbrock 14 inch open type. I hooked up the IAT and that works fine. What about the vacum line for the thermac? All i did was plug the vacum line. The idle seemed a bit lower with it plugged. Will i do any damage without it?
Old Apr 15, 2004 | 02:43 AM
BTW its on my 92 RS with a 305 TBI.
Old Apr 15, 2004 | 02:56 AM
Oh yea, If anybody needs my stock intact old aircleaner assembly with intake tube let me know.
Old Apr 15, 2004 | 01:35 PM
camarokid04's Avatar
what he said, i did the same thing to my car and just plugged it as well.
Old Apr 15, 2004 | 02:39 PM
Damon's Avatar
Keep your old air cleaner assembly. In some areas the Thermac system is needed to pass a visual emissions inspection.
Otherwise, No, it isn't strictly speaking necessary.
When I converted my TBI car to an open element I just zip-tied the IAT sensor to a location that was right next to the air filter element. Good enough to read reasonably accurately (verified through Diacom scans of the ECM) and no negative effects that I could tell.
Old Apr 16, 2004 | 04:23 AM
WHT87RS's Avatar
removing your stock Thermac air cleaner will pretty much affect your cold driveability, since there will be no more hot air piped in to the air cleaner to aid in the cold start to normal operating temp(helps atomize the fuel better so the car is easier to drive when cold,not so rich). Also your IAT sensor won't accurately read the inlet air temp but won't set a code if its just lying there or tie wrapped to something. Another thing is if you live in a state with strict emissions testing this will definitely fail the visual check, and also if there is a tube or hose that runs from the EVAP canister or PCV system you've affected its ability to get rid of hydrocarbons from the fuel tank and crankcase.
Old Apr 16, 2004 | 03:46 PM
The IAT is back in the stock location. I drilled a hole in the base of the aircleaner and put it where it was originally.
Ben91RS
Feb 12, 2005 04:37 PM
CamaroZ28Coupe
Oct 23, 2003 09:06 PM
Dragons91RS
Jan 8, 2003 11:15 PM
