why so why so
Old Apr 20, 2004 | 06:28 PM
lordmetalz28's Avatar
why so why so
we did my rear tranny seal only leak a tiny tiny bit today, almost nothing really so little i canceled my appointment at the shop, whats the deal with this pos
Old Apr 20, 2004 | 06:51 PM
IROC-T's Avatar
Check the fluid level it may have leaked down below were it should be. Of course it could have been over filled also.
Old Apr 20, 2004 | 07:05 PM
kevin 2.8's Avatar
it only leaked a little today? maybe it wasnt seated all until now.. or maybe some oil sludge filled the leak a little
Old Apr 20, 2004 | 08:30 PM
no it didnt all leak out its a tiny bit over the full line, and i put lucas in 4 days ago, who knows it was dripping fast this weekend
Old Apr 21, 2004 | 06:32 AM
greezemonkey's Avatar
Why don`t you crawl under that thing and just put a seal in it? Think I`ve seen 4 or 5 post about that leak
Old Apr 21, 2004 | 04:53 PM
why dont you come to my house, install air tools so i can get the bolts off sploogemonkey, thier tight i cant get enough leverage to get those strap bolts off, its going to the garage tonight
Old Apr 21, 2004 | 10:18 PM
steve10358's Avatar
3rd Gen Tech Moderator
Lordmetal- please shorten your sig to 5 lines.
Thanks!
S.
Old Apr 21, 2004 | 10:32 PM
Wishmaster's Avatar
I was wondering when that was going to happen, must follow the rules.
Old Apr 21, 2004 | 11:25 PM
trackbird's Avatar
Just put it in gear, set the brake and use a box end wrench and a mallet to pop them loose (poor mans impact gun). I don't think there is room to actually get a socket and air gun in there. That is how I've gotten a few tight ones off. And, as a side note, if they are overtorqued, they can smash the caps on the U-joint causing early failure, be gentle when reinstalling (torque specs are important). I hope that's helpful.
That's my method.
Good luck!
Old Apr 21, 2004 | 11:28 PM
steve , what is my signature, are you talking about my quotes,
Old Apr 21, 2004 | 11:31 PM
i think that should do, got to support the yanks go yankees
Old Apr 21, 2004 | 11:37 PM
Wishmaster's Avatar
I think what he means is that we are only suppose to use up 5 lines with our sigs and your using 13 I think and thats including your spaces, lines with nothing in them.
Count how many line below the solid line. I guess?
Old Apr 22, 2004 | 06:47 AM
steve10358's Avatar
Yup bud, that's correct. LordM- you should start a website, and then link to it. That's what I did to cut down on what I had in my sig.
S.
Old Apr 22, 2004 | 04:24 PM
do i still need to shorten it , or is it good now?
Old Apr 22, 2004 | 05:30 PM
trackbird's Avatar
I still count 11 lines. Just making an observation.....
