305 TPI to 350 TPI
Old Apr 25, 2004 | 08:21 PM
easyrider394's Avatar
305 TPI to 350 TPI
When swapping a 350 tpi into a original 305 tpi car I asumme you need to change the chip, or do you need to change the whole cpu?
Old Apr 25, 2004 | 08:54 PM
Black6SpdTA's Avatar
Assuming you'll be using the same ECU (I.E. 730 or 165) between motors, a chip swap will be sufficient.
Old Apr 25, 2004 | 09:06 PM
87DJP2001's Avatar
Few other items also, such as 22# FI and the knock sensor for starters.
Old Apr 25, 2004 | 11:07 PM
aklim's Avatar
In the Chilton book, it tells you tath the MAF cars had a KS that hooked up to the ESC module. In 90-92, the SD cars had a KS that hooked directly to the ECM.
Old Apr 25, 2004 | 11:24 PM
well my buddy has a 305 tpi car...and a 350 hes rebuilding. we are swapping in the 350 in a month or so. I just wasnt sure about the computers. He has bigger injectors for it. Hes taking all the tpi **** off the 305 and putting it on the 350 as far as pulleys and intake and fuel system go. I'll tell him about the knock sensors.
Old Apr 26, 2004 | 12:24 AM
aklim's Avatar
I would think you could swap out the injectors and EPROM and the rest should be the same.
Old Apr 26, 2004 | 01:36 AM
Sitting Bull's Avatar
I know a guy here in Calgary who is running his 350 on his old 305 TPI setup. He didn't change his injectors at all and it is running just fine. Our altitude of 3500 ft. might have something to do with it, but I don't know much about fi.
Old Apr 26, 2004 | 02:17 AM
aklim's Avatar
AT WOT, he might run lean because the injector cannot go any further. What did he do to the EPROM? Maybe he compensated by running more pressure with longer pulse width?
Old Apr 26, 2004 | 02:57 AM
Don't know, Aklim. Haven't talked with him for a year or so.
G-BODYT56
Jan 14, 2022 11:14 PM
HAWG
Sep 25, 2015 11:41 AM
Tarizza
Sep 20, 2015 03:26 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
