Boring a 355-cost/size?
Old Apr 28, 2004 | 09:13 PM
JJEXP's Avatar
Im going to have my 355 bored out, what did you guys pay for yours? Also, whats the biggest I can go? I was hoping for 396, otherwise I'll just end up buying a 400 block. Thanks
Old Apr 28, 2004 | 10:02 PM
rskrause's Avatar
Moderator
Re: Boring a 355-cost/size?
If your motor is already a 355 it has been bored 0.030". Depending on exactly what you have in mind, you can bore it out a bit further, but many people consider the max for hi-po use 0.030-0.040" anyway. Some people bore production blocks 0.060" over, but I wouldn't. Boring, even out to 0.060", will only increase your displacement to 360ci.
Do you mean building a stroker?
Rich Krause
Old Apr 28, 2004 | 10:06 PM
JJEXP's Avatar
Re: Re: Boring a 355-cost/size?
Rich Krause
I did have that in mind
Old Apr 28, 2004 | 10:16 PM
kmook's Avatar
Advanced Tech Moderator
General engine buildup should be posted in a Gen Spacific Engine Tech Forum. Transfering to 3rd Gen Tech.
Old Apr 28, 2004 | 10:17 PM
rskrause's Avatar
Moderator
You can make some big displacment small blocks starting with the 350. But I think 383 is probably ideal unless you want to go pretty far out on the price/performance curve. Lots of parts available for a 383 and nothing much is required to get the 3.75" stroke crank to fit. Cost depends on what you building. A very different rotating assy is needed for mild street motor versus a high rpm screamer or a blown/juiced combo.
Rich Krause
RUENUF
Mar 13, 2016 03:37 PM
IndyZman
Oct 22, 2015 02:17 PM
Z Power
Sep 19, 2015 11:19 PM
heus
Sep 8, 2015 12:01 PM
