Fan control (via a relay) and idle on carbed 350
The stock 305 TPI ran the fans off the ECM via a temp sensor and a relay or something like that. When I did the 350 swap, I hot wired the fans to "key on" power, so they run all the time.
I read this will burn the fans out. Is there a way to replicate the factory fan setup without the computer so that the fans will only turn on when the temp goes above a certain setpoint? I've got a 165* tstat as well.
Also, the engine idles 900RPM nice and smooth in park. In gear at a dead stop however the idle surges from 700 to 900RPM, randomly dropping to like 600RPM. Any ideas?
Dave
Dave
It's a fairly straightforward setup right? A sensor screws into the block runs to a relay which controls the fans, similar to the stock setup just independant. You wouldn't happen to know any place that sells such a setup?
If it's a vacuum leak, why does it only surge in gear, why does it idle perfectly in park?
Park is a no-load situation. Vacuum leaks and misfire issues are both less noticable under no load (except on EFI cars, when a vac leak nearly always causes a high-idle condition.)
The fan control is just that....a temp. switch and a relay. Some of the switches screw into the intake/head, but most of the aftermarket ones just have a probe that pushes between the radiator fins. Run a search on Jeg's or Summit for "fan control" or something similar.
Jul 4, 2005 05:00 PM
ferraricameron
Jul 29, 2002 07:46 PM
