Where to get fuel injectors?
Old Apr 20, 2004 | 02:16 PM
DanTheIROCMan's Avatar
Just received some bad news from Cruize Performance. They won't clean my injectors because they say mine have the highest failure rate in the industry. They are the original Multec grey/silver fuel injectors. So, anyone know where I can buy some decent replacements? The car is stock so I want to keep them at stock specs and have a limited budget. Any help would be appreciated.
Old Apr 20, 2004 | 02:20 PM
krazzycowgirl's Avatar
Summitracing Go with the ford Motorsport ones.
Old Apr 20, 2004 | 03:35 PM
aklim's Avatar
You seem to have a host of problems, don't you? I wouldn't get the used ones but I'll throw in a vote for the Ford ones. They are probably going to be 19 or 24 pph ones that you get tho. Good time for you to get a truely custom EPROM for your car to take car of the richness of the 24 pph ones and optimize your engine performance.
Old Apr 20, 2004 | 04:21 PM
Yes, I do. It all seems to point to the fuel injectors allowing too much fuel into the car and leaking when the car is off. I can really smell gas in the intake plenum when the car is off and sitting for awhile. I have also seen numerous posts that say the stock fuel injectors on these cars are crap. So I think I'm just going to replace them and if they don't help, then so be it.
Old Apr 20, 2004 | 04:58 PM
Will injectors out of a 1992 Mustang 5.0 work? They are 19lbs and look like the same connector.
Old Apr 20, 2004 | 04:59 PM
Zepher's Avatar
I guess you are needing these soon.
I have a set of 24lb Accels that I am probably going to sell once they come off of my friends car next month.
They have less than 10K miles on them so far.
Old Apr 20, 2004 | 05:05 PM
I could wait a month, but I have read that Accels are not the best choice. Also, I don't want to get an adjustable fuel regulator or custom tune right now so I need to stick with 19lbs. Thanks anyways though.
Old Apr 20, 2004 | 05:07 PM
Zepher's Avatar
you're running 19's in your 350? did you swap from a 305?
Old Apr 20, 2004 | 09:19 PM
aklim's Avatar
I would think you could get by with 24pph injectors if your stock ones were 22 pph but are you sure you have 19 pph injectors? Those are on 305s and 22 pph ones are on 350s
Old Apr 20, 2004 | 10:01 PM
OH, I just thought I read some posts that said the 19s were stock. So that's what I was going by. So a stock 89 350 TPI L98 should be 22s? Man, good thing you guys told me that. I was about to buy some used 19s...
Here's thing. I don't want to get a custom tune and don't want to have to get an adjustable regulator at this time. So I really need to stick with stock specs. So what fuel injectors should I get then? I didn't see any Ford injectors that were 22 pounds. So am I screwed??
Old Apr 20, 2004 | 11:15 PM
IROC-T's Avatar
You could go with 24's ,the computer should ajust for the extra richness and bring it back to specs,plus give it a little more umph.
Old Apr 20, 2004 | 11:21 PM
Thats what I was thinking.
FMS-M9593A302 1986-95 5.0L Mustang, 24 lb./hr. fuel injectors
$219.88
Old Apr 21, 2004 | 01:14 AM
So I don't need to do anything else with the 24 lbs? My concern is that my car already seems to be running rich, but hopefully that's because my injectors are bad and letting too much fuel out.
So my computer should compensate? Then what about going to 30lb injectors? They are the same price. Or is there a limit on what the computer can adjust for?
Also, in my 99 Cobra, I can't just throw on bigger injectors without recalibrating the MAF. Are Chevys different than Fords in this respect in that they don't need their MAFs recalibrated?
Old Apr 21, 2004 | 09:05 AM
aklim's Avatar
You have a MAF system and the ECM can compensate to a point. 30pph is way past that point.
Old Apr 21, 2004 | 02:28 PM
87DJP2001's Avatar
22# stock injectors, try gmpartsdirect for a good price.
AdsoYo
May 2, 2018 03:21 AM
daves91z28
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
