Running Rich....Bad Computer?
Old Apr 26, 2004 | 04:25 PM
WhiteKid's Avatar
Went to the garage where my car is today. They readjusted the valves which werent that off but the car was still running rough. They hooked a computer up to it and the car no matter what runs really rich. What could do this? Could it be a bad ecu? How can I fix this?
Old Apr 26, 2004 | 06:05 PM
Rice Killer87's Avatar
if they are hooking up a scan tool to it its reading rich,thats normal b/c the car will never say either rich or lean,at idle its never 1 or the other.
aside from that,a bad oxygen sensor could cause it to run rich as well.
while they have the scan tool hooked up,hold it at 2,000 RPM's or so and see what it reads then. also while its hooked up,u can read the TPS voltage (i know on a Snap On u can anyway..) and see what it is,at idle it should be at about .54V
hope that helps
Old Apr 26, 2004 | 06:58 PM
aklim's Avatar
Try cleaning the TB and the IAC and the IAC housing too. That, if it is clogged, might cause it to run rough and possibly rich.
edman
Jan 22, 2015 02:45 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
Absolute Z28
Jul 19, 2002 02:21 PM
