Difference between T-5 and T-10
Old Apr 27, 2004 | 09:42 AM
WhiteLightnin83's Avatar
could anyone explain the main difference between a borges and warner T-5 and T-10 tranmission. i'm looking to change my 350 turbo over to a manual but i want something that is relatively cheap and will take a bit of abuse. i'm runnin a rebuilt 350 sbc in my 83 z28 and can't take the boredom of the automatic anymore. i know the T-5 is only rated at like 330 ft/lb of torque and i'm pretty sure i'm over that mark, however, i know absolutely nothing about a T-10, i only heard a friend of mine speaking about it. any suggestions or help much welcomed, thanks.
Dustin
Old Apr 27, 2004 | 10:18 AM
trackbird's Avatar
The T-10 is the latest (t-10/Super T-10) version of the "classic 4 speed" such as used in the late 2nd generation cars. You will have no overdrive, but it is regarded as being more durable than a T-5. It also uses an external shifter instead of the internal rail shifters used on the T-5/T-56. I'm not sure how well the linkage will fit in the trans tunnel of a late model car (only because I've never tried it, it may fit just fine). I still suggest the LT1 version of the T-56 as the best swap option for a 3rd gen (I've done T-5 and T-56 swaps in automatic 3rd gen cars).
Old Apr 27, 2004 | 12:40 PM
Z28SORR's Avatar
It will not fit just fine. The 4 speed linkage is off set to the left. And will require you to modify the trans tunnel. Also you will not be able to use the stock center console.
Old Apr 27, 2004 | 12:48 PM
trackbird's Avatar
I guess that answers that question (which is why I said I wasn't sure). Thanks.
Old Apr 27, 2004 | 12:58 PM
angel71rs's Avatar
G force has mods to take a T-5 to higher hp levels. That would be the best of both worlds, an easy to swap in tranny with the strenght to take the power of a healthy engine. And overdrive. You can buy the tranny outright or a kit.
But I don't know if it's available for GM T-5's or Ford only. You can ask them:
http://www.4speeds.com/
Old Apr 28, 2004 | 08:08 PM
rottonj's Avatar
Tremec makes a 5 speed that will handle 450 ft lbs of torque.I dont know if it is a regular or tko or if its just an adapter to mount the one for the mustang, but it is a bolt in for the camaro.
Old Apr 29, 2004 | 01:18 PM
Z28SORR's Avatar
Not intended as a slam. Writing to fast didn't reread.
And I agree the best swap would be the T-56 or the Tremec TKO 5 speed, etc.
Old Apr 29, 2004 | 01:51 PM
trackbird's Avatar
Not taken that way. Just glad someone knew. I'd not tried to fit one and never even considered it as a swap in my 3rd gen so I really didn't know, but I suspected it would be tight if it fit at all.
WobblySausage
Oct 7, 2015 02:44 PM
NewsBot
Sep 30, 2015 04:20 PM
SergheiS
Sep 29, 2015 08:56 PM
Bxlt1
Sep 29, 2015 03:18 PM
