Driveshaft question
Old Apr 28, 2004 | 08:21 PM
mako350Z28's Avatar
Driveshaft question
Will a 4th gen driveshaft bolt into a 3rd gen or does it require some machine work to get it to fit?
Old Apr 28, 2004 | 08:57 PM
1984camaroz28's Avatar
direct bolt in
Old Apr 28, 2004 | 09:00 PM
87DJP2001's Avatar
This is a common question, and YES the 4th Gen Aluminum Dr
Shafts ( LT1 & LS1) will fit on 3rd Gen cars both manual and auto as a DIRECT bolt on without any modifications as long you get one that is complete.. Don't pay more then $150 for a used one, less if you can .
Old Apr 28, 2004 | 11:10 PM
mako350Z28's Avatar
thank you
Old Apr 28, 2004 | 11:17 PM
krazzycowgirl's Avatar
If you get a new one check ebay as well sometimes Lingenfilter sells their new ones on ebay for really cheap
Old Apr 29, 2004 | 01:00 AM
kandied91z's Avatar
yep, it really improves throttle response and although the weight difference is only a few pounds the rotational weight is great.
however, be leary down the road if you start adding some serious horsepower. for stock cars and under 300 horse you should be fine. up the power and put a sticky tire on the car and you may twist it.
i bought mine used for 100....you should check junkyards too as sometimes i've seen them go for 50.
Old Apr 29, 2004 | 11:12 PM
87roc_t56's Avatar
I have read many conflicting reports on these aluminum shafts actual strength. Some guys claim to have have run 1.5 60' with these stock shafts yet others claim they break with stock LS1 6spd's on street rubber. Does anyone know what they are rated for?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
blac94Z
15
Mar 2, 2015 12:00 PM
ddr698
Jan 31, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
