Damper for engine
Old Apr 25, 2004 | 08:42 PM
zrs's Avatar
zrs
Damper for engine
Need to get a harmonic damper for my engine. Swapping a 305 for a 350 w/ voterc heads and LT-4 Hot Cam on my 92 RS. Need input as to which size/brand to get. Any input would greatly be appreciated.
Old Apr 25, 2004 | 09:06 PM
92RS305#2's Avatar
i think there was an earlier post on this stating you can use the stock one. i'd wait for someone else to post if i were you though, i'm no expert but i try
Old Apr 25, 2004 | 10:07 PM
aklim's Avatar
Unless you are planning some high revving, why not go witht he stock one? If you are going to spin it up that high you should get your rotating assembly balanced first.
Old Apr 25, 2004 | 11:39 PM
zrs's Avatar
zrs
I am planning on getting it balanced but need to get a damper. I already ordered the external balanced flexplate but need to get the damper.
Old Apr 26, 2004 | 12:25 AM
aklim's Avatar
Stock dampner would do then.
Old Apr 26, 2004 | 06:39 PM
TheGreatJ's Avatar
Did you say "externally balanced flexplate?" Because that won't work on a 350....externally-balanced denotes parts used for a 3.75" stroke 400 crank. If you're using a regular 350 crank (3.48" stroke) you need an internally-balanced flexplate and damper.
Stock works fine as long as it hasn't slipped and you check the balance on it. If you're set on aftermarket, Fluidampr makes the best.
Old Apr 26, 2004 | 10:40 PM
zrs's Avatar
zrs
Maybe I was missed informed. I was told that some chevy 350 were externally balanced. This doesn't look good now especially now that I just purchased the item (flexplate) on line.
Old Apr 27, 2004 | 06:11 PM
TheGreatJ's Avatar
All SBC 350's are were internally balanced. Late model (1-piece rear main seal) engines do have a small counterweight on the flexplate, but it's still classified as an internally balanced engine. The counterweight is just to accomodate the new seal design.
Make a phone call to wherever you ordered the part and tell them you clicked the wrong button or something....they shouldn't have any trouble changing your order (unless it was already shipped.)
Old Apr 27, 2004 | 06:53 PM
zrs's Avatar
zrs
Thanks for the info, will contact the seller and see about changing the flex plate. Appreciate your help as well as others.
Old Apr 29, 2004 | 11:07 PM
zrs's Avatar
zrs
Forgot to ask which size should I get, the 8" or 6.7" damper.
Old May 2, 2004 | 01:00 PM
TheGreatJ's Avatar
The smaller one (although I thought it was 6.25") should be the one you need.
Old May 2, 2004 | 07:27 PM
zrs's Avatar
zrs
Thanks for the size, now time to go on Ebay and find a Fluid damper.
willismoons
Feb 14, 2015 08:42 PM
STR FTR 1
Feb 10, 2015 10:36 PM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
